Creo 9.0.4 is going to 'not responding' state. Tried re-installing, clearing cache.
Verified config.pro. Nothing seems to work. Could you help with some suggestions other than graphics card?
The same configuration for different users seems to be working fine, but only for one user, it's not working.
Your assistance would be greatly appreciated. Thank you in advance for your support!
Well, graphics driver issues is the easiest to blame when it only happens on 1 computer.
rename all config.pro, config.sup and ui_customization files.
Perform a classic test ... add following option at the end of an empty config.pro file and test Creo behavior.
graphics win32_gdi
Have this user login on another workstation and see if it is something in his Windows profile.
Are you using a PLM system with Creo? Try Creo in offline mode.
@BenLoosli Thank you very much for the response!
The user is currently using Windchill within Creo for check-ins. Yesterday, I noticed that their config.pro and CAD files are stored on OneDrive, which can cause slowness. We plan to move these files to a local folder/shared drive and verify if there is any improved performance.
If not, we will try out the steps mentioned. Your insights are welcome.
@BenLoosli We could see performance is improved when we move config.pro and other files out of One-Drive. But after few days, this is happening again, not very extensively but occurring. User is finding some issues in display when 'win32_gdi' is used.
so, we reverted and cleared the cache, kept the config.pro from shared network drive to his local, but still 'not responding' issue pops up.
The option graphics win32_gdi is for testing only. It disables opengl on your graphics card. If solves your initial problem, then you have a graphics card issue, Possibly you need to upgrade your graphics driver or if you have an approved graphics card you can use the "approved" driver.
Remove the graphics win32_gdi option to test the new driver. The graphics win32_gdi option will negatively affect graphics performance on all but the simplest models.
The other thing Ben mentioned is to completely remove all your config.pro/config.sup files and restart creo. If the problem goes away, then your issue is likely a config option in your setup. You'll have to troubleshoot your config files to find it.
