simplifying expression
ptc-6727461
Hi. I have the problem presented in the attachement. I need to replace the value of the determinant of the second expression with B, to make it simpler. I've tried with "explicit, B" but it doesen't work. How do i do that? Thank you
Here is the whole content of his file:
He has alreaday asked the same question here: http://communities.ptc.com/message/261653#261653
For reasons unknown to us he wants Mathcad to display something like
which I guess is demanding too much.
7 REPLIES 7
(To:ptc-6727461)
Can't see your file at the moment but the mathematical term for replacement is substitution. Mathcad has that built in. Use the 'substitute' symbolic keyword with argument {determinant}=B.
It is possible, if you tell Mathcad what you want it to give you. With:MatrixAlgebra.png
Yes, thats basically the way I did it in the file I posted. Not sure if it had helped.
Ok. I understood so the first thing i want to know is how do I insert that bold equal sign. Sorry but i'm a dummy
This boolean equal sign is accessible from at least two palettes ("calculator" and "boolean"). I usually use the keyboard shortcut Ctrl & +, but this may be different, depending on the keyboard layout you use - I am using a keyboard with German layout.
Thank you very much.
