Hello Everyone,
Good Afternoon,
I have a folder named "photos" in a ThingWorx repository Thing which keeps on updating as & when new images are added to it.
I wan to download this folder "photos" which contains multiple images on click of a button from Mashup.
Can anyone help me out with this.
Thanks in advance.
Aditya Gupta.
Haven't done things within ThingWorx for a while, but there are services that can give you the file list and download links for a file repository
GetFileListingWithLinks, then you'll have to execute each appropriate link.
Not 100% sure how to do the last part, sorry.
Thank you for your response.
The problem with GetFileListingWithLinks service is it provides link for each image which are there inside a folder.
Also I tried CreateZipArchive service with which I was able to create a zip folder and then used GetFileListingWithLinks to download the zip but, the problem I am facing is
1. CreateZipArchive service requires inputs(newFileName, path, files), so how to save these inputs as these won't be changing for me. I also tried saveinputset option but after reloading of the ThingWorx the input set is automatically erased.
2. I want to use CreateZipArchive service twice with different sets of inputs, since I want to download two different folders which are present in a repository.
Is there any way that I could call two different CreateZipArchive Service continuously with predefined sets of input in ThingWorx.
Do you have any idea how should I deal with the above problems.
I think links can be triggered with an event in a mashup I think or maybe explore the expressions capabilities.
As far as needing to do things multiple times, again I would recommend looking at what potential event triggers you can use for that.
Worst case might have to be a timer/scheduler
