Security Labels and Desktop Tools Integration
rleir
17-Peridot
Team
According to this Help page below, SL is compatible with DTI.          Too many acronyms!
  • SL = Security Labels
  • DTI = Desktop Tools Integration
https://support.ptc.com/help/windchill/r12.1.2.0/en/index.html#page/Windchill_Help_Center/securitylabel/SecurityLabelDTI.html
I have SL configured to pop up a Download Confirmation message window and wait for acknowledgement. However this just works for normal file downloads.  When I set the preference so I am using DTI, there is a blank popup which disappears immediately.
HelesicPetr
22-Sapphire I
(To:rleir)
Hi @rleir
If you say I have SL configured to popup...  Does it mean a OOTB configuration or customization?
PetrH
rleir
17-Peridot
(To:HelesicPetr)
Petr
It is an OOTB Security Labels config, without the Agreements options.  But any work with Security Labels feels like customization because when you make a mistake Windchill fails to start and you are digging through log files.  I hear that you can get a crash when the acknowledgement window pops up due to an config error. That's just hearsay, apologies.
So you're right, this question technically should not be in the Customization forum!
Maybe I should set the logging level to Info or Debug.  But would I set that system-wide? I want to see what goes wrong when you download via DTI.
Or maybe I should dig in and check if  DTI was  installed correctly.
cheers
rleir
17-Peridot
(To:rleir)
Specifically, the problem is that when using DTI, there is a blank download ack popup which disappears immediately.
When not using DTI, just the simple download preference, the download ack popup works correctly.
@HelesicPetr
HelesicPetr
22-Sapphire I
(To:rleir)
Hi @rleir
The point is that the DTI file is downloaded directly that is used by DTI.
I guess that there is a some condition that standard download mechanism is bypassed and it works as you've described.
PetrH
