hot to get vaultFileName of Family Table
Gucio
Hi All,
How to create query to get vaultFileName of FT??
There are articles on PTC
https://www.ptc.com/en/support/article/cs39037
https://www.ptc.com/en/support/article/cs337082
but I'm not able to create such query.
Any idea??
regards,
Krzysztof
HelesicPetr
22-Sapphire I
(To:Gucio)
Hi @Gucio
here is MSSQL example how to get vaultFileName with CAD Model file name
this works only for normal CAD Documents
select substring(convert(varchar(100),convert(varbinary(100), FVI.uniqueSequenceNumber, 256),2),3,14) vaultFileName,apData.idA3A5 as FvItem, apData.fileName ,MSTR.documentNumber, EPM.versionIdA2versionInfo,EPM.iterationIdA2iterationInfo, MSTR.CADName from wcuser.EPMDocument EPM
INNER JOIN  wcuser.HolderToContent CONTENT
 ON CONTENT.idA3A5 = EPM.idA2A2
 inner join wcuser.ApplicationData apData
 ON apData.idA2A2 = CONTENT.idA3B5
 inner join wcuser.EPMDocumentMaster MSTR
 on MSTR.idA2A2 = EPM.idA3masterReference
 inner join wcuser.FvItem FVI
 on apData.idA3A5 = FVI.idA2A2
 where MSTR.CADName like 'plech.prt' and EPM.latestiterationInfo=1
Following example shows how to get vaultFileName for FamiliTable
 inner join wcuser.EPMContainedIn CONTIN
 on EPM.idA2A2 =  CONTIN.idA3A5
 inner join wcuser.EPMSepFamilyTable FT
 on FT.idA2A2 = CONTIN.idA3B5
 inner join  wcuser.HolderToContent CONTENT
 on CONTENT.idA3A5 = FT.idA2A2
 where MSTR.CADName='plech.prt'
Hope this can help.
PS:  the select function changes a RealNumber value stored in a database to the final FilaVaultName value that is used in a storage
PetrH
Gucio
(To:HelesicPetr)
hi Petr,
unfortunatelly I receive "Error at Line: 1 Column: 26". But in the meantime I used bello query:
SELECT
epdm.name,
epd.versionIdA2versionInfo||'.'||epd.iterationIda2iterationInfo VERSION,
to_char(fvi.uniqueSequenceNumber,'FM0XXXXXXXXXXXXX') "VAULT FILE",
fvm.path
FROM
EPMDocumentMaster epdm,
EPMDocument epd,
HolderToContent htc,
ApplicationData ad,
FvItem fvi,
FvFolder fvf,
FvMount fvm,
EPMSepFamilyTable sft,
EPMContainedIn ci
WHERE
epdm.idA2A2=epd.idA3MasterReference
AND htc.idA3B5=ad.idA2A2
AND htc.idA3A5 = sft.idA2A2
AND epd.idA2A2 = ci.idA3A5
AND ci.idA3B5 = sft.idA2A2
AND ad.idA3A5=fvi.idA2A2
AND fvi.idA3A4=fvf.idA2A2
AND fvf.idA2A2=fvm.idA3A5
AND epdm.cadname='ahu03-3-81453.prt'
Krzysztof
HelesicPetr
22-Sapphire I
(To:Gucio)
Hi @Gucio
It is normal if your database has different name in my case wcuser
So you need to change all wcuser. to your databse name.
the SQL is written for MS SQL so for Oracle you need to change it to correct form.
I run the SQL script under database admin user so I always use nameDatabase.TableName in my SQL examples.
PetrH
