请尽快与我联系
ZW_10422446
请尽快与我联系
I am using Creo Parametric Release 5.0 and Datecode5.0.0.0
在一个零件中,如何将一条曲线的局部线段进行复制,并使生成一个复制曲线的端点与两个坐标点重合
Hi @ZW_10422446
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Could you clarify what you're hoping to achieve or understand in this case?
  • Are you trying to duplicate a segment of a curve within the same sketch or as a separate feature?
  • Should the duplicated segment be editable independently, or remain linked to the original?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
This will increase your chances to receive meaningful help from other Community members.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
(To:ZW_10422446)
OP translated to English.
How to duplicate a local segment of a curve in a part and make the end point that generates a duplicate curve coincide with the two coordinate points
Your request is a bit vague.  Is this what you are trying to do?
References / chain details / options: Change each end to trim at reference and select the desired reference (point, plane, line, edge, surface, etc).
