I have a need to bring in a 2D object and place it on the surface of a 3D part. The 2D object would be the artwork for a printed circuit board which has the component outlines and designators. Typically, this can be exported as DXF. The model would be of the printed circuit board. Under "Sketch" the only formats allowed are "DWG", "DRW", or "IGS". I converted the "DXF" to a "DRW" by bringing it into a Pro/E drawing, but there are so many little segments, it took forever to try and align the graphic, which I gave up on. What works best here? Has anyone already solved this problem? Thank you.
