A ToolBox for Creo Parametric ??
ptc-4442928
I am new to Creo Parametric and trying to switch from SolidWorks. The thing I've noticed while working on assemblies is that i couldn't find a Toolbox feature (similar to Solidworks) from which I can insert different types of fittings (i.e. washers, nuts, bolt and screws ... etc.).
For the moment I am modeling every fitting that I need to use, which is very boring and time consuming...
Is there a toolbox that I am missing in Creo, or does is it realy not there in the first place???
Akrum
welcome to the forum.
If you are a maintenance customer you can download the hardware parts from this link :
https://www.ptc.com/appserver/auth/it/esd/product.jsp?prodFamily=ENG
otherwise you have to use websites like mcadcentral, pemnet..etc to download your hardware parts.
You must have additional licenses, Rohit. I only see Pro|E, WF, and Creo downloads at that link.
if you go to the Release Wildfire option..you will find the Wildfire Library Databases.
you are most welcome!
Thanks a lot Rohit!
