I am using the ANSI Flare Bevel weld symbol in PTC Creo 8.0.8.0, and there seems to be a large space between the flare bevel symbol and the flush and grind symbol. So much space that the flush and grind symbol hardly appears to be applied to the weld symbol.
Can this space be reduced relative to the rest of the symbol? Or maybe another solution? I've tried changing the font size, but this makes everything smaller. I've also tried the different weld symbols (simple, combination, braze, and ISO) but none of these options are a good solution.
Not looking for a solution involving adding a sketch line and/or Text Note.
Thanks for your time,
Kevin
