About the changing in dimensions
ta.p
hi guys,
i created 3d model in inches but i need in mm how to convert the dimensions of the drawing or we have to draw the 3d model from beginning help me guys
StephenW
23-Emerald II
(To:ta.p)
Go to FILE - PREPARE - MODEL PROPERTIES - units CHANGE.
Select the units you want and push SET.
Depending on how you modeled your part, if your model is 1 mm = 1 inch, select the INTERPRET OPTION (1" Becomes 1mm)
MartinHanak
24-Ruby II
(To:ta.p)
  • open part
  • click File > Prepare > Model Properties
  • in Units line click change
  • select millimeter unit system and click Set button
  • select Convert Dimension option and click OK
MH
Martin Hanák
