WF4, M080 I'm trying to convert a part from relative accuracy to absolute. Theunits are metric, mmKs, current accuracy is the default 0.0012 relative. When selecting 'absolute' and 'enter value' I'm presented with thedefault choice of 0.0001 mm. That's way too tight, I want the mmequivalent of that value in inches, so I enter 0.00254. Pro/E tells methe minimum value is 0.0117, try again. Even in an empty part, that'sthe minimum value, Here's the odd thing, if I accept the default of 0.0001mm, it will takeit, but enter my own value lower than 0.0117 and it's out of range. Also, if I change the units to the Pro/E default (inches), set theabsolute accuracy to 0.0001", then change the units back Pro/E willreport that it's now set at 0.0025mm, the value that was invalid before.Why won't Pro/E let me enter this value directly? Doug SchaeferThis thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
LinkedIn
