There may be something simple I'm overlooking, but I cannot find how to place a call out (note format) for a counter-bored hole in a Creo 3.0 2D drawing. The counter-bored hole was created in the 3D model using the Hole command.
Any help would be appreciated.
David,
What JLG has suggested is the most robust way of labelling holes, also they are fully parametric. I have in many cases had standard hole notes fall off of drawings and also issues with them not updating correctly when the model is changed.
I'm using Creo 2.0 and assuming that it's the same in Creo 3.0.
I modify one dimension to show the others with it, like this:
Okay, I see what you did.
So I'm assuming then that Creo does not have a command in the 2D environment that automatically picks up the information from the 3D model that a counter-bore hole was created. As an example, in SolidWorks and Inventor when creating a 2D drawing and adding the dimensions, a command within the 2D environment "Hole Callout" will automatically place the information about the counter-bored hole (like you showed) when the diameter is selected.
Thanks, JLG
In addition, the leader points to through hole diameter; ASTM Y14.5 shows the leader pointing to the counterbore diameter.
Is there a way in Creo 2.0 to point to the counterbore diameter, other than creating a note?
David,
Do a google search for "CALLOUT_FORMAT". You can create your company's own .hol files. These are the hole table files that Creo uses to create all the hole and c'bore sizes in the hole feature command. In my case, I changed the data in the columns in the hole files that I wasn't using such as drill size, etc. with my own info. In the hole file, there's an area for the callout format that you can customize with parameters to show only what you want in your drawings.
When it's all done, you'll select the new custom hole type in the modeling environment to create your hole/c'bores. as you do now for different thread types.
Matt
David,
Thanks, Colin
I figured it was something I was missing.
Thanks again.
Dave
