Hola,
Me equivoqué en la medida y al añadir la pieza en el conjunto era pequeña en relación con las otras piezas. ¿Es posible agrandar toda la pieza en si en el conjunto?
Un saludo
I had made a mistake on the size of on piece and when I added that piece to the combination or essemble it was smaller than the other pieces of the combination or essemble. How can I make that piece bigger ?
Salute
Re-dimension it or you can scale the whole model using Operations > Scale Model. If it was just a mistake of making it in mm instead of in or cm you can go to File > Prepare > Model Properties and click change next to units, and either create or select a different set of units and use interpret to keep dimensional values, but change to the new system of units.
