Annotation in 2D drawing assembly
KG_14283785
3-Newcomer
I am using Creo Parametric Release 10.0 and Datecode10.0.7.0
i want to know if it's possible to add texte in a annotation from a part in a assembly drawing without modifie the annotation of the part.
For exemple i import a annotation like Ø10 frome a part in my drawing assembly and i want to add ( ) around the annotation for see (Ø10) in my drawing.
thank you for your support.
Kévin Goasdoué
Hi
A little trick in dimension text:
(@O&d6:1)
d6 - part dimension name
1 - part session ID
You don't import annotations from the model into the drawing, you choose to display them.
Hence any edits will also appear in the model.
You can create the dimension you require in the drawing as a reference dimension. It will already have the brackets.
Hi
(@O&d6:1)
1 - part session ID
Hi @KG_14283785
You may add parenthesis "( )" in drawing just by selecting dimension  > Dimensions text and add ( ) as per requirement.
Thanks.
