Applying Stress/Strain as loads in Creo
ptc-6458004
I am new to modeling and simulation and I was wondering if it is possible to apply Stress or Strain loads instead of the standard force etc. loads in creo. I want to simulate shot peening and would like to use a residual stress field or plastic deformation field to apply my loads but I cannot seem to find a way to apply Stresses and Strains.
SylvainA.
(To:ptc-6458004)
Could it work by using a (huge) pressure load ?
