Area of a Cosmetic Sketch
mjenkins
Is there an easy way to calculate the hatched area of a cosmetic sketch?
(other than creating a protrusion of it and measuring it's area)
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
Hi Michael,
Print it out along with a 1 X 1 square, cut them both out and weigh them on a milligram scale.
That's how those wacky calculus doctors do it to check that their approximations are valid.
Otherwise, extrude it baby!
Pro/E will do a cross-sectional area, but not with a cosmetic.
Best regards,
Frederick Burke
Hi Michael,
Simpler than extruding using the sketch is to highlight the sketch feature
and make a fill (flat surface) then you can get the area or perimeter of the
surface. Does not leave you with a meaningless extrude if you don't need
one. Redefine the sketch and the Fill surface updates automatically. I
would name the fill as an Area feature.
Of course you could pick fill then choose the sketch but that takes a couple
more steps.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
wfalco
(To:mjenkins)
I tried this earlier and it works nice.
mjenkins
(To:mjenkins)
Genius! That works great!
In Reply to Brent Drysdale:
Hi Michael,
more steps.
New Zealand
DDI +64 3 358 1093
www.taitradio.com
I could do this on a sketch, but not a cosmetic sketch. Am I doing something wrong?
Doug Pogatetz
Mechanical Design Engineer
WF4 M070
