Assembling analysis
MichalLukac
Assembling analysis
hello
Is there an analysis in creo or some addon that can simulate if a component is possible to assemble without interferences with others parts in real assembling process?
E.g. I have an assembly (machine). and now need to assemble a part into the assembly. To put the part in correct place I need to follow
some path and do rotations with the part to avoid collisions with the assembly(I mean this in real, by manufacturing process)).
I can simulate this in creo during assembling the part, manually moving and rotating the part in small steps but it is very difficult.
thanks for help
vzak
6-Contributor
(To:MichalLukac)
Michal,
Unfortunately the answer is no, Creo doe snot have assembly feasibility analysis.
- Vlad
StephenW
23-Emerald II
(To:MichalLukac)
The only way I have ever done this is the method you described, using small increments manually moving and rotating the part. There will be nothing "automatic" about this process.
I think not. In mechanism you specify connection between parts...
But here the problem is to find (if it exist) the route from position A to position B without colliding with others parts.
vzak
6-Contributor
(To:MichalLukac)
Michal,
- Vlad
