According to the document "Capability Comparison ofPTC Creo®Parametric™3.0" at http://www.ptc.com/File%20Library/Product%20Families/Creo/Shared%20Files/PTC_Creo_Parametric_3-0_Version_Comparison.pdf, Creo support AutoCAD drawing import, but "*Installation of relevant libraries required".
When I installed Creo 2.0, I didn't see any option to install separate libraries to support this feature.
Where can I get these libraries?
Thanks!
if you are active on Maintenance, then ask PTC Support.
Martin Hanak
