If you would like to create your own balloons; Pick insert from pull down menu. Pick "Balloon". Next menu opens; pick "no or with leader". Half way down menu it shows Horizontal & Vertical. Select which one you want. Below that pick "Make Note". Next window opens, pick how to attach the balloon, and if you want the leader what will be the point of leader. Pick where you want the point of the leader or the balloon. Select "OK" Select "Done" Pick where to place the balloon itself. "Pick on screen" Type the text or number, hit enter, if you want more than one number or text, type the next, then enter, so on and so on. You can edit this string with the text editor to change it if you like. The balloon editor stays in the vertical if that was your last method. Keep that in mind for the next string if you want them to be horizontal.
