I want to create a BOM from assy, which would contain a family table of it. Each innstance of assembly has different components. Is that possible in Creo to create a BOM table which would show all instances of the generic assembly with the same indexes and (different) quantities?
For example
Assy1 | Assy2 | Assy4 | |||
INDEX | QTY | COMPONENT DESCRIPTION | COMPONENT NAME | ||
1 | 1 | Bracket | BRACKET1 | BRACKET2 | BRACKET3 |
2 | 6 | Plate | PLATE1 | NO | PLATE2 |
3 | 3 | Angle | ANGLE1 | ANGLE1 | ANGLE6 |
We have a lot of such drawings in AutoCad. Assemblies are big and it is monkey work to fill them manually.
Please help.
Michael
have u used repeat region 2d instead of simple? Please try out that option.
Welcome to this forum
