Within a Creo Cad .asm, we have included imported CAD which includes Surface geometry.
When viewing publishing in Creo View, those surfaces do not appear.
In Creo view
- opened within assemblies, any objects created as surfaces are blanked out
- opened as a part, they are shown as a block
( see attachment for both examples )
Is there a proper setting for our cad worker to publish this correctly
( I know it should work. As a test, I performed a save as from creo and was able to produce a .pvz file showing the surfaces, so I'm fairly certain this issue relates to the cad worker settings ?
thanks
In our setup, the quilts/surfaces in imported or shrink-wrapped models get published as "Construction" surfaces, it might be the same for you...
My solution was to enable display of such entities:
Hello Paul;
Thank you for the reply.
It worked perfectly for us.
