Hello
I made an assembly, where I want't to show a few reference dimensions , on the top plane.
I triet everything, but i can't make them show.
I tried to create dimensions manually with the buttons on the right. They were created like on the picture, but they don't show up, only if i click on "show annotations". But there i still can't click on them, also can't erase the wrong ones. I can't click on ok, etc..
How should I edit/select them, delete the bad ones, and make some of them always show?
Thanks!
