Can we add STUD in creo IFX library
ICAD_Support
Hello How can we add stud in Creo IFX lib.
There is an article which states that it is not available  yet.
https://www.ptc.com/pt/support/article/cs336035
Is there any workaround available
I suppose the workaround is to create it manually as you would with any other part. Once you've assembled the first instance you could add the rest using Pattern and the studs will be auto-placed in the holes you've made with Pattern in the main part.
