Can we add or delete a dimension in creo drafting using pro/program?
i am trying to automate the extrude feature by suppressing or unsuppressing. i want that to reflect in the drawing as well.
if i understood the question right you should use Drawing program
Although this is an old question -
Pro/Program changes model and assembly logic only. It does not affect drawings. You can use Toolkit if this function is required.
