I have a drawing that I have for specific reasons had to use all manual balloons. After placing all the balloon I decided it would be advantages of me to us split/quantity balloons. But I can't seem to figure out how to change them now that they are placed. Or if its even possible to change them. It may not even be possible to have a manual split balloon.
Hi Mikael,
When you say you used "all manual balloons", how exactly did you create these balloons? Please provide the steps and the picks in the ribbon menus.
It would be beneficial to have this information, in order to let you know if you can convert those balloons to parametric split/quantity balloons.
Amit
Split and merge for balloons only work with balloons tied to a repeat region.
