How do I get every part within an assembly to reference that assembly's coordinate system when displaying the calculated mass properties of each part? I want to be able to know the mass properties in each part with respect to the main assembly's coordinate system without manually opening each part and changing the coordinate system reference within the mass property analysis tool.
Above I have taken a screenshot of the material properties shown within a model tree for an entire assembly. Each part's mass properties are referencing that part's coordinate system. I want each part's mass properties to reference the master assembly in assembly 1021320.
