Clearance and creepage distance
YsnbKmy
I am using Creo Parametric Release 5.0 and Datecode5.0.3.0
In the clearance and creepage distance analysis, when there are multiple parts in the electric net, it seems that it may not be detected even though the clearance is not secured. If the clearance of other parts is shorter, it seems that it may not be detected. If it is another part, is it possible to output the result if the clearance is insufficient for each? If the detected part is corrected and recalculated, the next part will be detected, which is inefficient.
Translated with Google Translate on 28.04 by Iuliana Nuta
Dear customer,
Tank you for reporting CCX issue with Creo 5.0.3.0 .
Based on your description , issue seems related to path that are not computed properly for clearance and creepage.
Similar issue was reported in Creo Parametric through SPR 8090046 , and such SPR was fixed in Creo Parametric 4.0 M090, Creo Parametric 5.0.5.0 and Creo Parametric 6.0.1.0 and above versions.
Please update your Creo release to a more up to date release / version in order to get better results.
Best regards
Jean-Claude
Dear customer,
Best regards
Jean-Claude
YsnbKmy
(To:jchelle)
Thank you, Jean-Claude.
I checked this issue with Creo Parametirc 7.0.2.0 and found no problem.
Because of reported another issue with 7.0.2.0, I will get later version.
Best regards
Ysnbkmy
