Color Map or appearance.map - how I create a color with texture?
gabrielrocha
Hi, I'd like know how I create a color with texture?
in the files *.map have the structure below
"RED_SHINY"
1.000 0.030 0.030 0.900 0.900 0.800 1.000 1.000 1.000 1.000
0.000 0.250 0.500 1.000 0 90
NO_TEXTURE NO_TEXTURE NO_TEXTURE <------ What I put here?
anyone can help me?
thanks
best regards
Gabriel Rocha
-.br
Where exsactly are those map files. My apearance file doesnt have NO_TEXTURE writen anywhere.
Anyway im guessing first NO_TEXTURE is for bump, second for image and third for decal.
Try typing location of image file instead of those. Like C:\img.jpg etc.
Dear Davor,
I'm trying to apply a texture in pipe spec.
In folder pipe/master_catalog has piping_appearance.map, or in folder graphiclib\graphic-library\color_maps.
I dont understand the logical, but in file graphiclib\graphic-library\color_maps\plastic.map has the text below
"Beige_Plastic"
0.841 0.801 0.715 0.390 0.830 0.690 0.130 0.953 0.956 0.849
0.000 0.120 0.010 1.000 0 90
NO_TEXTURE speckle.tx1 NO_TEXTURE
and in same folder has the file speckle.tx1
Hmm didnt realise you were talking about piping.
up
Hi Gabriel...
From what I can see, the piping appearance map goes by the rules of the OLD color.map files dating back to Pro/E 2001. I used to have documentation on precisely what went in these files but after we moved to Wildfire 2, 3, and above, I switched over to the new appearance.dmt format.
I've looked through my old Pro/E 2001 files but haven't located a color.map file with textures saved in them yet. If anyone out there has Pro/E 2001, they can answer your question easily by creating a new color, adding a bump, image, and decal map... and saving out the resulting file. PTC used to have an example file on their website but it has been pulled down.
I'll keep looking...
lkoeniguer
(To:gabrielrocha)
Hello Mr. Rocha,
Did you find a solution ?
I try to add an appearence on this piping map file and I have the same issue on Creo 2.
Thanks in advance
