Configuration Parts?
Norman
I have an assembly that will need to come in at different positions (same p/n but, ie, one comes in at 0,0,0 and another same p/n comes in at 0,0,1, etc).
Is there a way to set up, based on the configuration, so that it comes in the right position depending which configuration to pick? I don't know much about Configurable Part, but from the assembly standpoint which is require to set it up for multiple configurations? Any mating requirements? Where can I find some help on this?
jsarkar
(To:Norman)
Configuration is used i guess in solidworks software. However you can do the same with snapshot. Click on drag icon in model tab of assembly file then create snapshot.
Norman
(To:jsarkar)
There's an option in Windchill that handles PLM. I was told it's configurable parts, but I don't know anything about it. It's another level above WTPart.
