Counterbore tolerancing
dgrobe
6-Contributor
im trying to add a tolerance to my counterbore on a hole.  but i cant get it to show up..
here is my dimension callout..
@D  x 21.70
v &d79  x &d78
i need the &d79 to show the tolerance.  i checked the model, and its showing in the model.
thanks
Kevin
(To:dgrobe)
Check the drawing options, tol_display needs to be set to yes. You may also need to set the display from the dimension properties.
