Create a datum point on COG with creo parametric using relations
ggiuliani
7-Bedrock
Here there is a trick to position an offset datum point on model COG using the following relations:
$d1 = mp_cg_x("","DEF_CSYS","")
$d2 = mp_cg_y("","DEF_CSYS","")
$d3 = mp_cg_z("","DEF_CSYS","")
where d1, d2 and d3 are the names for the datum point offset dimensions and DEF_CSYS is the name of the default coordinate system.
It works also in assembly mode.
This feature can be saved in the startpart/assembly file.
Note: In this video the automatic mass property calculation is disbled by config.pro.
Ciao
Gabriele
pimm
(To:ggiuliani)
Gabriele:  It is very good that this can be done.  It's a shame that the base seat of Creo can't do this itself.
Does this work with complex curvature or just with fairly basic shapes?
Thank you for sharing this idea!
