Creating 2d drawings from 3D models in creo parametric
dpearce
I created some models in creo elements direct express which I saved as stl files and would like to convert them to 2D drawings in Creo Parametric. Is this possible, and if so how?
KevinBradberry
(To:dpearce)
To learn drawings, check these out:
http://www.ptc.com/products/proe/tryout/tutorial4/printable_page.htm
http://mrbrunelle.org/proE/tutorials/06_DRAWINGS.pdf
As for STLs in drawings, I'm not sure now. With Wildfire 3.0 I remember being able to select edges and faces of STL models for placing dimensions, but now with Creo/5.0 I can't do it. Hopefully someone else will chime in.
bduncan
(To:dpearce)
Thank You, Where can I find "Get Data, Import"?
bduncan
(To:dpearce)
Thanks, Is there a way to create a drawing from the imported stl file?
bduncan
(To:dpearce)
Yes
KevinBradberry
(To:dpearce)
STLs are made up of many triangles (possibly thousands) so if you must have a drawing, but can't re-model the part, then set your drawing views to shaded, meaning they will be colored and shadowed.
You would make a drawing for the STL part as you would any part. Have you made a drawing in Pro/e before?
No, I'm brand new to the software.
KevinBradberry
(To:dpearce)
