I am trying to create an expanded metal part using diamond-shaped protrusions and copying them. Then I am patterning a copy of that feature. This is taking an incredible amount of time to regenerate.
Is there a MUCH BETTER way to create this kind of part without being bogged down by regeneration times?
Michael P. Locascio
(IIRC & without testing it myself...)
Create one diamond as a surface. Pattern the surface. Solidify the first diamond feature. Pattern the solidify.
That will be faster than creating them as a solid from the beginning, but it’ll probably still eat up a lot of time during regen.
In Reply to Michael Locascio:
Michael P. Locascio
I would suggest taking a look at Leo Green's video on Turbo patterns....
I've had pretty good luck with creating the part sheet size I wanted with an extrution and then creating a large field of the expanded metal with a single cut extrusionand then patterning the field up to get cover the overall part size. I found that the larger the field you can create in that first single extrusion the less regen time it will take. Still, there is none-the-less alot of geom for it to run through.You can play around with the size of the field and the number in the pattern to get to a place you can live with.
