Creo 2.0 3D Section Edge Display
asmith-3
I am currently Using Creo 2.0 and I am trying to use the 3D section in a drawing and the edges of the parts in the assembly I am using do not show up so the parts all blend together. How do I get the edges to show up so the parts do not blend together.
9 REPLIES 9
please attach some picture.
Martin Hanak
Martin Hanák
David I tried that and it still did not work. I'm wondering if there is a config.pro file for this, or something in the drawing properties that may affect this.
That was a link to an enhancement request.
Creo does not do shaded section views so you must have done a section cut in the assembly. In that case, you should be able to show the edges by using display of the view "shaded with edges".
The section is a zone section. But that still does not explain the assembly not having edges in the drawing.
If you use "repaint" after applying the shaded with edges, the edges should show up.
I think that edges are not visible simply because this functionality is not implemented for ZONE views.
Martin Hanak
Martin Hanák
