Creo 2.0 stopped running and dispalying on my laptop computer
ekucuk
Here is the story
I normally work on laptop computer but use a connected monitor as a display ( hp 2035 LCD monitor)
Some days ago, suddenly the monitor lost the view and never came back again.
I disconnected the cable and tried again but no change.
I restarted the computer but no change.
Then, I disconnected the monitor tried running Creo 2.0 on laptop computer.
It looked as if the program starts but no display on the screen.
I borrowed another monitor, connected and tested that way, Creo 2.0 worked.
I disconnected monitor and try to run Creo 2.0, did not work.
I found an hp 2035 monitor just to see if it works, it worked with and without hp monitor until I restarted the computer.
Now, use a Lenovo LCD monitor, Creo 2.0 runs with it but still does not run without a monitor.
There was no problem until hp monitor broken.
I used to work with or without a monitor.
How can I fix this problem?
Thanks!
Emrullah
please show us the settings from following dialog box.
MH
Martin Hanák
kdirth
20-Turquoise
(To:ekucuk)
Are you seeing the icon on the task bar?
From the Task Manager or the task bar you can minimize then maximize the program.  This will usually bring it back to the main window.
