Creo 2 datum targets with diameters
JLG
I don't know if I am seeing a bug, or if I have a configuration problem. When I create a datum target on a drawing using a diameter dimension (from a cosmetic feature in the model, or created dimension in the drawing), I get doubled diameter symbols, e.g. "ØØ8".
Has anyone else seen this? Do you know what might be causing this? I've seen this in Creo 2 builds M040, M050 and M060.
I've found I can remove the diameter symbol from the dimension used, and then the target will show properly on the drawing, but I really hate to do that. I need a better solution.
Janet Grove
jnegrini
(To:JLG)
I know is quite an old post but apparently that issue was not looked at and we can find the same problem on Creo 3.0. There is  a document on PTC website, but it is not very helpful. I am having users complaining about this too.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS136711
Hopefully they will fix.
Juliana
