Is there a config setting to default the extrude to remove material instead of adding on? When making cuts and extrudes in a design it would require less mouse clicks to remove material by default.
Thank you in advance.
C.Reed
Hi Cheryl,
Sorry, but that's not possible. There isn't a way to set the default to be Remove Material. You can create a mapkey that starts the extrude dashboard and clicks the Remove Material icon.
Amit
Hi Amit,
It would be nice to be able to change this in the configurations. I will try the mapkey.
Thanks so much.
Cheryl
