Creo 3.0 new functionality and missing features...
rsobecki
Hello I just installed Creo 3.0 and noticed nice improvements within Freestyle feature, but also noticed missing features like Solid Free Form or Surface Free Form.
My question to the Audience is: will Freestyle cover the functionality of mentioned missing features?
BR
Roman
TomU
(To:rsobecki)
Per the help documentation:
To Create a Freeform Surface or Quilt
1. Set the enable_obsoleted_features configuration option to yes. The Surface Free Form command appears on the Commands Not in the Ribbon list.
2. Add the Surface Free Form command to the desired user-defined group on the ribbon.
Note: For information about customizing the ribbon, see the Related Links.
3. Click Surface Free Form. The SURFACE: Free Form dialog box opens
enable_obsoleted_features yes, no*
Enables the following commands on the Commands Not in the Ribbon list when set to yes:
Blend Between Surfaces
Blend Section to Surfaces
Conic Surface and N-sided Patch
General Blend
Pipe
Project Section Blend
Solid Free Form
Surface Free Form
TomU
(To:rsobecki)
General Blend
Pipe
Solid Free Form
Surface Free Form
rsobecki
(To:TomU)
Great thanks for your valuable and fast response!
I also set to yes "allow_anatomic_features" and have got ability to use e.g. local push and more
Thanks again and regards
Roman
what happens when a person without those settings open the file?
and why would they take out tools if there isn't a better replacement? or is there?
If you'll open a part with those features you'll se them without any problem and of course you'll be able to redefine it. Only without those settings you can't add them.
I gues at the beginning that PTC remove those features and that was the source of my investigations - perhaps in future they create something new. At the moment the best candidate from my point of view is Freestyle - after surface creation with this feature you'll be able to use replace surface or just solidify etc.
