Creo 3 M180 drawing is not updated
ptc-2173756
7-Bedrock
With the new release M180, we have noticed that when updating the model, the program doesn't update the drawing. This is a problem... Has anybody experienced the same? Is it possible to solve the problem? DB
Problema risolto
Cambiando il parametro di config.pro   da  save_display yes   a  save_display no
Secondo il tecnico di PTC sia yes che no dovrebbero funzionare alla stessa maniera, ma probabilmente con le nostre impostazioni aziendali è meglio save_display no .
<Community Manager Edit>:
Problem Solved
Changing the config.pro parameter from save_display yes to save_display no
According to the PTC technician yes and no should work the same way, but probably with our company settings It is better to save_display no. Changing the config.pro parameter from save_display yes to save_display no According to the PTC technician, yes and no should work the same way, but probably with our company settings it's better to save_display no.
Problema risolto
Problem Solved
