Hi everyone,
What's the correct syntax for Creo 4.0 to stop throwing this error about profile-tolerance:
The underline appears as soon as the (U) symbol is put into the tolerance box.
That appears to be correct. Creo does give me an error as soon as I add the U symbol, but it goes away if I put in an appropriate second value and click off the gtol.
May be the gtol settings in you detail options.
Hi, thanks for the quick feedback. I ask few more questions:
- are you putting spaces before / after the (U) symbol?
- are you making this FCF in the model or in the drawing?
- M version of Creo 4.0?
Works with or without spaces.
Creating it in the drawing.
4.0 M130
I guess I have an answer; I made my annotations in a combination state of the model. The underline disappears if I make the Gtol in the drawing mode.
I'd be interested if anyone has tried this out in Creo >4 to see if this has been "fixed"?
