Hello, is it possible to create a flat harness with wires that are not in direct contact?
As in picture 1, it is composed of separate wire. the problem is when I decide a start point, I can not go and look for another point on a non-attached wire.
I would like to know if it is possible to do everything in one flat harness or if it is necessary to separate each wire that does not touch into different harnesses?
Hi @TM_10264935,
Thank you for your question.
Anurag
