Is there a way in creo cabling to bundle several harnesses together and still be able to generate the flats for each harness? We have four harnesses, and are putting sleeving on the common routes and want it to be shown in the model.
I tried making a harness with four subharnesses, but the flat doesn't generate properly with a shared bundle.
If you need more info, let me know.
Thanks!
CREO 9 // Creo Schematics 4
I tried to bundle several cables also and so far I failed to do it also. Perhaps some more experienced user knows whether it is at all possible.
As a workaround...
br,
Lars
As a workaround...
br,
Lars
Thanks for looking into it. I was hoping to avoid using workaround, but if it's the only way, it is what it is.
