Maybe this havs already been reported and fixed in V19.
When selecting an object and RMB to start Mirror from context menu, I noticed that the icons don't match the command.
For instance, you can select Vertical and it will mirror vertically on selected point. It's just the icon that doesn't match.
I also noticed the same mistake for other operations.
On the subject of context menus, how can they be modified to add commands?
In Modeling you can select the File menu and select Customize. Someone forgot to add this to the menu in Drafting.
Mike
I can not test the v18 currently.
But in Express 6 it looks like this
Since Express6 corresponds to the v19 that is probably solved.
Best regards.
Friedhelm
Thanks Friedhelm!
Any thoughts about customizing the context menus?
Mike
Hi Mike,
I have not found anything yet, but also not thoroughly searched, because we use the classic interface.
But I find it a pity that PTC does not make it possible so as in modeling.
