Creo Schematics plus Creo View for electrical documentation
BillF
A few years ago, I did some experiments for using the ability of Creo View to show two windows with parts being cross selected between the 3D model and the harness done in Creo Schematics.  Select an item in the schematic and it would highlight in the model.
At the time, I could not get enough of the items from the schematic to have the proper data in the EDA file for the linking to be practical without a lot of manual work.
I have heard via the Tech Committee for Routed Systems that some parameters may need to be set to make the linking work well but I have forgotten who the person was that commented about it.
If you know someone that has successfully used this feature, can you comment here.  This could be a great help to service or support people.
MT_7837378
(To:BillF)
You will need to set parameters for the models in Parametric and Schematics
For Parametric:
REF_DES
For Schematics:
MODEL_NAME
Their values should match.
This way Illustrate will create an automatic match. If a match is not automatically created you can manually match them in Illustrate and publish the PVZ file that could be viewed in Creo View.
I hope this helps.
BillF
(To:MT_7837378)
Are you saying that
    Parametric:REF_DES should match Schematics:MODEL_NAME
or
Parametric:REF_DES should match Schematics:REF_DESS <and> Parametric:MODEL_NAME should match Schematics:MODEL_NAME ?
MT_7837378
(To:BillF)
The value of Schematics:REF_DESS should match the value of Parametric:MODEL_NAME
