You can now select a sub assembly and restore it to its original location quickly and easily in Creo View 2. The method in Creoo Vew 1 and earlier required more steps and was frustrating to users. This video shows the "old" workaround and the "new" approach.
Creo View training is available at http://www.creo-view.com.
