Creo View Express : 3d Annotaions
pdavid
Hi, Iam currently using creo view express 3.1 to view the .pvz files.
Actually iam giving 3d annotations in creo parametric 2.0 software for the 3d models and then the file is converted to .pvz file to view it in creo view express software 3.1.
Issue is that iam having 1 assembly which has 3 parts in it,
In Creo parametric,
Step 1: Iam taking 3d annotations to all the 3 parts
Step 2: Iam taking 3d annotations to the assembly.
Here when iam opening the part, respective 3d annotations that i gave to the part will be displayed.
Similarly if i open the Assembly respective 3d annotations that i gave to the assembly will be displayed and part annotations wont be displayed in the assembly.
Now iam converting the entire assembly to .pvz file to view it in creo view express 3.1.
In Creo View Express 3.1
Step 1: Iam opening the same assembly file in .pvz file,,but it is showing both the annotations that i gave in part and also in  assembly together in that .pvz assembly file
Pls support, how to see the dimensions clearly without merging.
0 REPLIES 0
