Hello all,
In Creo View, is there a way to carry over the views I make in the model as well as the sections and simplified reps to the pvz file?
Please clarify the source of the "Model". Is it from Creo Parametric?
Madhavi
Sorry about that, it's from Creo Elements Pro.
No problem. Simp Reps and Planar cross sections come through to Creo View. Please use the Recipe Editor to select the appropriate options so they are published to Creo View format.
Madhavi
Thanks for your quick help! Unfortunately I'm Still a little new to Creo, I used Inventor all through highschool and college, where and or how do I get to or use the recipe editor?
