Creo View Improvements
ehorn
  • Better way to view Cable Designation's from Creo Parametric other than showing the value in the metadata for each part when published as a standard publish.
    • Can this be obtained from a positioning assembly publish?
  • Search:
    • Not very user friendly.  CTRL F doesn't search attributes even though the UI implies it does
  • Mobile:
    • Creo View needs a better mobile/tablet solution
      • Windows 8.1/10 Pro on mobile should have a UI change to make buttons bigger to use with fingers instead of just the mouse
    • API to develop customized client experience
0 REPLIES 0
