Creo View Problem
bwudtke
Creo View Problem
For some reason when i open up my assembly in creo view, not everything will show up in the viewer. It seems that any time I have a part with a import feature in it, the geometry will not show up. Is this a bug, or normal?
This happens in both creo view and creo view express.
Brock,
try the following...
In Creo View ... open a part which is not displayed when you open assembly.
In Creo Parametric click File > Open > Preview and check preview of an assembly and problematic part.
If problematic part is not shown then it does not contain graphical data which are used in Preview window and also in Creo View.
You have to set config.pro option SAVE_MODEL_DISPLAY properly and re-save problematic part.
Good luck
Martin Hanak
