Creo cabling: Connector parameters editing issue.
nshete
Hello All,
I am facing issue with cabling parameters updation for connectors.
I have a 3 pin connector; with 3 wires routed to it for first three pins. But, for this connector the parameter "NUM_OF_PINS " is defined as "9".
Now, I want to redefine the Num of Pins as "3". But unable to do it as I do not have the logical input for this.
Is there any other way to define it.
Nitin
Kevin
(To:nshete)
‌For me it updates but you have to close and re-open the dialog box to see the updated table
dwachter
(To:nshete)
if it is not working for you at the moment, you can also try to write a short logical file on yourself. search the Internet, you will find a lot of examples how you write a logical file with editor.
Greets, Dominik
